Activity › Forums › Apple Final Cut Pro Legacy › KeySpan Setup
KeySpan Setup
Posted by Ian Liuzzi-fedun on December 28, 2007 at 3:34 amI am new to using keyspan and cannot get the adapter I have to talk to my RS-422 S-VHS deck
Ian Liuzzi-fedun replied 18 years, 9 months ago 5 Members · 10 Replies -
Arnie Schlissel
December 28, 2007 at 4:52 amAnd you’re keyspan adapter is connected to what? This is an FCP forum, so I’ll assume you’re using FCP. what version? What capture card? What port on the mac is it connected to? Are you using the latest driver from Keyspan that’s recommended for your version of Mac OS & FCP?
And perhaps most important, are you sure your S-VHS uses RS-422, and not RS-232?
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Ian Liuzzi-fedun
December 28, 2007 at 5:19 amLatest drivers and versions on everything. The keyspan uses a USb port and yes I am using FCP. My deck uses 422
Thaxter Clavemarlton
December 28, 2007 at 3:38 pmIs the deck in REMOTE?
Do you have the “control” setting in FCP set correctly?
Ian Liuzzi-fedun
December 28, 2007 at 4:32 pmSorry I was kind of vague in the last post. Yes I have the settings right adn yes the deck is in remote. The error I am getting is no communication
Christopher Wright
December 28, 2007 at 10:43 pmYou first have to make sure the USB device is enabled in Apple System serial device preferences, and then you have to go into the system setups in FCP and manually select the Keyspan for device control.
Ian Liuzzi-fedun
December 28, 2007 at 10:50 pmthe keyspan serial assistant recognizes it and I have set it up manually – maybe it is my cable that converts mini sub 8 to 9pin
Steven Gonzales
December 29, 2007 at 4:12 amIf this setup hasn’t worked before, you might have the wrong cable. There are many mini-din 8 to DB9 cables for printers, but they don’t work for deck control since they are pinned for RS232.
Addenda has a mac to rs422 cable listed here if you want to buy one. I had to make one in an emergency once, and it’s way easier to buy one:
https://www.addenda-elect.com/product.htm
Also, pipeline digital https://www.pipelinedigital.com/adaptcm9.html
Here’s the mac mini din 8 to rs422 9pin breakdown:
TXD- mac pin 3 rs422 pin 8 RX-
GND mac pin 4 rs422 pin 4 AND 6 RX Gnd, TX Gnd
RXD- mac pin 5 rs422 pin 2 TX-
TXD+ mac pin 6 rs422 pin 3 RX+
RXD+ mac pin 8 rs422 pin 7 TX+———
/ 8 7 6 \
( 5 4 3 )
\ 2 1 /
\ 1 2 3 4 5 /
\ 6 7 8 9 /
Steven Gonzales
December 29, 2007 at 4:13 amIf this setup hasn’t worked before, you might have the wrong cable. There are many mini-din 8 to DB9 cables for printers, but they don’t work for deck control since they are pinned for RS232.
/ 8 7 6 \
( 5 4 3 )
\ 2 1 /
\ 1 2 3 4 5 /
\ 6 7 8 9 /
Ian Liuzzi-fedun
December 29, 2007 at 4:27 amthanks. Sorry, I don’t read the ending stuff with all those pin to pin stuff – I have never made more than a coax cable. Anyway – I am returning my cable and going for a different one and I will let you know
