Activity Forums Apple Final Cut Pro Legacy Keyspan adapter
  • Keyspan adapter
    Posted by Jason on May 24, 2006 at 4:25 pm
    I bought a Keyspan adapter to convert RS-232 to USB to control my DSR20 DVCAM deck. I installed the Keyspan software and restarted the computer, but when I open FCP and try to change my device control to the Keyspan, there is no option for Keyspan, USB or anything related.
    Jerry Hofmann replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 24, 2006 at 5:47 pm
    You should have the option to use the serial port supplied by the keyspan… does your system profiler see a serial port now? If so, you should be able to select RS-422 for control of the Sony deck… the one that’s right for this is here: https://www.keyspan.com/products/usb/USA28x/ The others aren’t gonna work don’t think.
    Jerry
  • Jerry Hofmann
    May 24, 2006 at 5:48 pm
    There’s software drivers too you need to run to have the mac see the Keyspan. if you don’t have them, you can download them from Keyspan.com
    Jerry
