Activity Forums Apple Final Cut Pro Legacy Keysapn RS-422 Trouble…
  • Keysapn RS-422 Trouble…
    Posted by Devon Brough on May 15, 2006 at 10:11 am
    I need to play out straight to a PVW2800 Betacam Deck, i have no capture cards so i am taking the signal out through firewire through a DSR 45 and then via component into the Beta deck. I need accurate timecode though, so i am using a keyspan USB adapter going to the RS422 port on the betacam…
    I downloaded the latest drivers, installed, rebooted… Then in Audio/Video settings under device control i made a new setting for sony RS 422 and changed the port to the correct on… Now when i go into capture mode all it says is No Communication. I have tried different ports and a different usb port but to no avail…
    Any suggestions?
    Ron James replied 20 years, 4 months ago 2 Members · 1 Reply
  • Ron James
    May 15, 2006 at 6:24 pm
    Where did you get your cable to attach the Keyspan device? The pin configuration has to be correct. I had to have one custom-made, which works fine. Initially, though, I was pointed to a certain cable (by my local Apple dealer) which did *not* work.
    G5 Dual 2.7 GHz
    2 GB RAM
    OS 10.4.6
    FCP 5.0.4
    QT 7.0.4
