Activity › Forums › Apple Final Cut Pro Legacy › Keynote, QT, FCP = viewing problems
  • Keynote, QT, FCP = viewing problems
    Posted by Mike Brumbaugh on November 11, 2009 at 4:26 pm
    Help needed:
    I started with a Keynote presentation (made by someone else) with slide size of 1920×1080 that included photos, video clips and transitions (no audio).
    Exported the Keynote to a QT movie with the following settings:
    Format set to Custom, Video = Full size (1920×1080)
    Settings = Apple ProRes 422 Compression with 25 fps, Data Rate = Auto
    First issue is when I play back the QT Movie, the videos do not keep the same slide delay that was set in Keynote. The video clips delay for a long period before transitioning to the next slide. Also noticed some of the photos and text are not as clear as when in Keynote.
    I import the Mov into FCP, edit timings, export to Compressor using Apple ProRes 422.
    The final project was put onto a DVD (via Toast) and shown on a large screen (16:9) in Germany. I was told NTSC and PAL would work on this system.
    Second issue is the presentation was not visible on the TV screen and only had black borders around the edges. It seemed as the presentation was too big to display.
    My main question: Is the Keynote slide size important when considering what the final project will be viewed on? What slide size is good for movie import to be viewed on an NTSC big screen 16:9? What slide size is good for PAL big screen 16:9? Why are my photos and test not clear when going from Keynote to QT?
    Mike Brumbaugh replied 16 years, 10 months ago 2 Members · 3 Replies
  • Gary Adcock
    November 11, 2009 at 4:41 pm
    [Mike Brumbaugh] “Format set to Custom, Video = Full size (1920×1080) “
    this is an HD frame not an SD frame size, unless you were working with BluRay this is too large.
    [Mike Brumbaugh] “I import the Mov into FCP, edit timings, export to Compressor using Apple ProRes 422. “
    The new version of keynote needs to be manually recorded to get the timing correct, there is a function within Keynote for this under the file menu called Record Slideshow.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Mike Brumbaugh
    November 11, 2009 at 10:00 pm
    What is the best SD frame size? What is best for viewing on a big screen (16:9)?
  • Mike Brumbaugh
    November 12, 2009 at 3:30 pm
    After I record my Keynote and export to QT, my video clip starts but then hangs up. The movie is still running but the video is not playing. I have a few text slides before and after the video slide with transitions. All slides transition okay. Any thoughts?
