Activity › Forums › Apple Final Cut Pro Legacy › Keynote, FCP and bad Quality
  • Keynote, FCP and bad Quality
    Posted by Mike Brumbaugh on November 5, 2009 at 8:30 pm
    I am new to the Keynote experience but here is my story and suggestions are appreciated:
    GOAL – Take a Keynote Present w/animated slides, photos, and short video clips and export to Quicktime for a .mov file, then take the .mov into FCP for edits and render in Compressor to burn a DVD. Final DVD will be used at trade shows around the world (Europe, Asia and USA)and displayed on a wide screen (16:9).
    MY EXPERIENCE – I have used various settings to export the Keynote
    to Quicktime and the quality of the photos and some text is poor. I saw this even before I imported into FCP. It appears to be some setting(s) when going from Keynote to Quicktime.
    MY QUESTIONS – What are the best Keynote to Quicktime settings (resolution, codecs,…) to make a PAL version?
    What are the best settings to render from Compressor for a PAL version?
    Tom Brooks replied 16 years, 11 months ago 2 Members · 1 Reply
  • Tom Brooks
    November 6, 2009 at 1:37 pm
    It depends on your sequence settings in Final Cut. Look at the parameters. Keynote works with square pixels. Set up your slide size (Document Inspector) to the square pixel equivalent of your FCP sequence. Export Quicktime in the highest quality codec you have (right on up to ProRes 422 HQ if you can). Set the frame rate to match your sequence. If your sequence is DV, finish the edit and then change the sequence compressor to the high quality codec of your Keynote video. Set sequence to render all YUV material in high precision. Render the sequence.
    Read up on ProRes 422 HQ. It may be better to use regular, non HQ ProRes 422 in your case.
    The basic method is to set slide size and frame rate to match sequence. Export in a high quality codec. If your sequence already uses that codec, great. If it’s a lower quality codec, such as DV, change it to the higher quality codec of your Keynote (at the end of your edit).
