Activity Forums Adobe After Effects KeyLighting still doesn’t show
  • KeyLighting still doesn’t show
    Posted by Geishagirl on August 20, 2006 at 1:57 am
    I was told that I could download a version of keylight from a website, but it would have a water mark on it because it was a trial version. I wasn’t too worried about the water mark because I wanted to see if it work, and if I would want to continue with the real thing, only problem is: when I downloaded it and everything, it didn’t show up on the Adobe AE options under effects (I think that’s the bar I’m thinking of)
    Did I do something wrong when I downloaded it, would there be any reason it wouldn’t show up?
    Yarin Manes replied 20 years, 1 month ago 2 Members · 1 Reply
  • Yarin Manes
    August 20, 2006 at 3:26 pm
    hey,well you must verify that you installed it in the right directory of after effects,which is x:\Program Files\Adobe\Adobe After Effects 7.0\Support Files
    anyway wherever you installed it…inside support files there’s a dir called plug-ins..install it there and you will see it in the effect menu.
