Activity › Forums › Adobe After Effects › Keylight question – keying out window
  • Keylight question – keying out window
    Posted by Clint Fleckenstein on January 24, 2007 at 7:19 pm
    I’ve got a sample window from a manufacturer and am told to chroma-key it rotating for one of the intro shots. I’ve given the direction to the studio guys to light the background properly, watch out for reflections, and frame as tight as possible. I’ve got a pretty decent key going, but as the window rotates, I get the crawlies on the left and right vertical edges. I’m going NUTS!
    Are there any little Keylight or matte choker tricks I’m missing here? Despite the fact that we’re shooting on miniDV, I’d still like to pull a decent key here.
    Cf
    Tclark replied 19 years, 8 months ago 6 Members · 9 Replies
  • 9 Replies
  • Clint Fleckenstein
    January 24, 2007 at 8:16 pm
    Yeah, it helped a little bit with the outer edges, but if I push things too far, I start to see the inside corners get rounded. I cringe everytime I have to pull a chromakey from DV, but people (with soft edges on their hair and clothes) are a cake walk compared to this!
    Clint
  • Tclark
    January 24, 2007 at 8:23 pm
    Are you using progressive footage? If not, it might help if you convert the interlaced video to progressive. Also you can use a matte choker.
  • Iancorey
    January 24, 2007 at 8:52 pm
    Depending on the circumstances it might not be an intolerable amount of work to apply a simple mask along that edge and animate the Mask Position.
  • Josh J. johnson
    January 24, 2007 at 10:11 pm
    Probaly a stupid question. How do you convert interlaced to progressive?
  • Erik Pontius
    January 24, 2007 at 10:36 pm
    Ahron “super tight junk mattes” tut might help with that. It uses the autotrace feature to automate a mask around a subject….
    Erik
    January 25, 2007 at 5:00 am
    I have the opportunity to have it re-shot progressive so I told the videographer to re-shoot on Friday. I’m using a matte choker but because of all the lines and angles of the frame of this window and the fact that it turns, that tends to give me wobbly shadows.
    Animating masks is an interesting solution, I would need 3 masks because it’s a 2-pane window, but because of the wide angle lens I get some perspective distortion that makes it look out of square. That, or maybe it’s the angle between the window as it pivots and the camera. In any case, I’m really close…hopefully shooting it progressive will help tune some of that out.
    Thanks for all the responses so far, I’ll follow up with my results.
    Clint
  • Jimmy Brunger
    January 25, 2007 at 9:34 am
    I’d seriously consider the masks option…if it’s just a static image rotating that sounds like a lot less hassle than a whole re-shoot.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
    January 26, 2007 at 6:24 pm
    You’re preaching to the choir there, but sadly I’m limited to that format.
    Shooting progressive and overseeing the shoot helped tons. We’re dealing with a 3-pane window here, so it’s got plenty of lighting challenges before we even get to the whole chroma-key thing.
    Cf
  • Tclark
    January 26, 2007 at 7:21 pm
    I am glad to hear that shooting progressive helped. Next time if you need to convert interlaced to progressive you can use DVFilm Maker to convert it. It is a cool program and it is only 99.00.
