Activity Forums Adobe After Effects Keylight problems with yellow
  • Keylight problems with yellow
    Posted by Joe Stas on August 22, 2011 at 6:08 am
    Hi
    I’m new to keying out green screen and I’ve noticed I always get issues with yellow becoming a brown/orange shade as soon as I key out the green screen.
    Can anyone explain why this happens and any solutions to fixing the problem? Thanks very much
    Joe
    Michael Szalapski replied 15 years, 1 month ago 4 Members · 3 Replies
  • Ben G unguren
    August 22, 2011 at 10:46 am
    Assuming you’re using keylight… Keylight automatically attempts to correct “spill” from the blue or green screen in the background (some of the light tends to show up on your subject, especially along oblique edges). This tends to add some warmth to the keyed image. In Keylight’s settings, change the view from “Final Result” to “Intermediate Result” to see the image without the color correction.
    The standard workflow as I’ve seen it is to let Keylight do it’s thing, then use color correction tools (curves, color balance, levels, hue/saturation — whatever works best for you) to balance the final keyed shot to the background plate. Some compositors prefer to use the intermediate result and use other effects to remove the spill.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adam Taylor
    August 22, 2011 at 12:19 pm
    your problem is caused by the way colour is generated. In RGB – yellow is comprised of both Red and Green, so when you tell Keylight to remove the green from your shot, it removes not only the pure green of your greenscreen, but also every other place where green is used to create other colours and shades.
    To avoid this you will need to learn about masks, holdout mattes, garbages mattes and rotoscoping. Its very rare to find a single easy plug-in that will pull a perfect key first time.
    good luck
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Michael Szalapski
    August 22, 2011 at 9:43 pm
    One way to deal with it is to use your layer with Keylight as a track matte for another layer of your source footage.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
