Activity Forums Adobe After Effects Keylight problem on noisy (video) footage
  • Keylight problem on noisy (video) footage
    Posted by Mark Thompson on January 29, 2015 at 11:04 pm
    Hi, I have a problem with Keylight on noisy footage. The person talking is in a studio with lots of light on a good green screen. Keylight keys the subject out but I omitted to light the legs below the knee. When I look at the source footage you can see noise there but when the key is applied it gets very noisy.
    If you look at https://www.youtube.com/watch?v=6lSZr1BInl0 from surfaced studio, at the end 5:54 on the Osaka Snake shirt you can see the effect I’m experiencing. However mine is much worse when I render.
    Anyone have any ideas what can be done to damp it down?
    CC 2014, footage is 50 MHz 4:2:2 25p.
    thanks
    Mark
    Tudor “ted” jelescu replied 11 years, 7 months ago 3 Members · 6 Replies
  • Todd Kopriva
    January 30, 2015 at 12:09 am
    Use the Key Cleaner effect with Keylight:
    https://blogs.adobe.com/aftereffects/2014/04/new-changed-after-effects-cc-2014.html
    After Effects product manager and curmudgeon
    After Effects team blog
  • Tudor “ted” jelescu
    January 30, 2015 at 7:30 am
    Use Intermediate Result from Keylight – this solves a lot of noise issues.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Mark Thompson
    January 30, 2015 at 10:30 am
    Todd,
    thanks for that suggestion. I have to study it some more but I latched on to “Reduce Chatter”, otherwise using default settings, and it made a huge difference.
  • Mark Thompson
    January 30, 2015 at 10:34 am
    Dave thanks for that. I will try that approach after I’ve done some re-shoots.
    mark
  • Mark Thompson
    January 30, 2015 at 1:17 pm
    Ted,
    could you expand on that a bit?
    thanks
    mark
    January 31, 2015 at 8:17 pm
    Using the “Intermediate Result” instead of the “Final Result” in Keylight removes some of the automated colour correction which can introduce artifacts and noise. I have been using this setting in most of my chroma projects combined with AE’s Spill Reduction and it works for most of my work. Of course in most projects I use the same tested setup with a well lit chroma and plenty of light, but I found this to work just fine in chroma footage that I received from other sources with a not so great setup.
    Tudor “Ted” Jelescu
    Senior VFX Artist
