Activity Forums Adobe After Effects Keylight plug-in question
  • Keylight plug-in question
    Posted by Steph Foster on April 19, 2009 at 8:23 pm
    Is it possible to do what I would describe as an inverse key namely,
    instead of keying out everything that is say green, to remove every thing which is not green and leave the green elements in a scene.
    i.e inverse the keyed out area ?
    steph.p.foster {at} gmail {dot} com
    Steph Foster replied 17 years, 4 months ago 2 Members · 2 Replies
  • Brian Charles
    April 19, 2009 at 8:58 pm
    If you make a normal key, in other words key out the green, then use that as an inverse alpha matte that should achieve what you want.
  • Steph Foster
    April 20, 2009 at 1:36 am
    Excellent !
    Many thanks Brian
