Activity Forums Adobe After Effects Keylight out of memory error
  • Keylight out of memory error
    Posted by Mark Longchamps on March 5, 2008 at 2:53 pm
    Hello. I just installed after effects 8 (Cs3) in a mac with 2 gigs ram and 2 Intel processors. I have 10 comps that are about a minute long each. I am doing a chroma key over a white background and a resize. I can render one at a time fine in the render que. However, when I select all 10 and hit render, after two or three get rendered I get a keylight out of memory error and AE crashes. I am a newbie to AE. Is there something wrong with my settings or a bug? Thanks
    Chrysa Choumeti replied 15 years, 4 months ago 3 Members · 3 Replies
  • Steve Roberts
    March 5, 2008 at 3:34 pm
    Search the COW for “secret prefs”. You need to use them to purge your RAM, since you have so little.
  • Mark Longchamps
    March 6, 2008 at 8:03 pm
    AHHH that is better! Thanks soooo much!
  • Chrysa Choumeti
    May 21, 2011 at 2:18 pm
    thank you very much mr. Roberts
    its been 3 days i m trying to find out a solution
    now it works!!!
