Keylight “Intermediate Result” applies Alpha Channel to RGB Channels – no multi pass keying possible
Hello,
I’m trying to do some multipass keying on a green screen material with the keylight plugin Version 1.2v10. The Keylight manuel says ” Intermediate Result – is used for multipass keying. The alpha is set as per normal, but the RGB values are not modified from the original source image.” When I use “Intermediate Result”; I get the source image with the alpha channel applied to it. Which means that there ist no green screen left for the second keying path. What did I do wrong. Do I have to tell after Effect not to apply the alpha channel? If so, how would I do it?I’d be very gratefull for any help.
Christian.
