Activity Forums Adobe After Effects Keylight Install Error
  • Keylight Install Error
    Posted by Jeff Tatro on April 23, 2007 at 11:51 pm
    Hay all, AE7 noob here. I installed the Production Studio Pro CS2. The Cycore Effects installed OK, didn’t try the others except Keylight. When I try to install I instantly get an error saying “Application failed to initialize properly…”. I navigated to the 3rd Party Software folder on the install disc 1, found the Keylight Install.exe, tried to run from there, same error. Does someone know how to install manually or do I have a call to Adobe in my future?
    Thanks in advance.
    “All things serve the Beam…”
    Jeff Tatro replied 19 years, 5 months ago 2 Members · 2 Replies
  • Mark
    April 24, 2007 at 2:09 am
    Mine installed right…..I would give Adobe a call….they should assist you for free as this is an installation issue.
    Mark
  • Jeff Tatro
    April 25, 2007 at 4:25 pm
    OK, thanks for the input Mark.
