Activity Forums Adobe After Effects Keylight Fine Tuning
  • Keylight Fine Tuning
    Posted by Caleb Armstrong on May 16, 2007 at 5:28 pm
    I just had my first experience using Keylight (I know, we’re a little behind the times) and I’m amazed at how powerful of a tool it is. However, I am still having some pixelation issues.
    I created a loose matte around the talent because she moves slightly while talking. Then I applied keylight to the remaining greenscreen elements. There are still some pixelation issues within the mask.
    Since this was my first experience with keylight, I’m not entirely sure what adjustments I can make to try and soften/eliminate the artifacts in the mask. Outside of tightening up the mask and animating it as she moves, are there any adjustments that I can make within keylight to help get rid of some of the pixelation?
    Thanks for all the help!
    Caleb Armstrong replied 19 years, 4 months ago 3 Members · 5 Replies
  • Caleb Armstrong
    May 16, 2007 at 5:29 pm
    Sorry, I forgot to mention that we taped on DVCPro, and the segment was imported into AE as a quicktime file. Hope that might help a little. I know that the digital format isn’t going to provide the best keying in the world, but I’m just curious about keylight. Thanks!
  • Mike Procunier
    May 16, 2007 at 5:57 pm
    Andrew Kramer did a great Keylight tutorial that’s available here on the Cow. Just search the Tutorial section by author & you’ll find it.
  • Caleb Armstrong
    May 16, 2007 at 6:12 pm
    Dave saves the day once again!
    Thanks a bunch!
  • Tony Rain
    May 16, 2007 at 11:25 pm
    this may or may not help but i exported a qt from avid xpress pro using the dvcpro codec and imported into ae, applied keylight and had terrible artifacts around my subject. i then tried exporting from avid using the avid dv codec and the terrible artifacts around the subject went away. so you may want to experiment with different codecs.
    thanks!
  • Caleb Armstrong
    May 17, 2007 at 1:22 pm
    Thanks again for all of the suggestions!
