Activity Forums Adobe After Effects Keylight causing noise.
  • Keylight causing noise.
    Posted by Danny Winn on January 14, 2010 at 8:08 pm
    I have read several previous posts on this topic but most were a few years old.
    I’ve keyed out some really great greenscreen shots using the Clip Black/White screen matte technique but those same great keying settings has caused moving noise in the black suit of the actor.
    Changing the Clip settings isn’t an option, they need to stay where they’re at for the awesome key result in. Has anyone developed a quicker technique (other than the duplicate each clip and matte out) to combat the added noise with a fancy color correcting trick or other? The “Noise reduction” effect doesnt look great, besides it seems that you can’t set it to a full HD frame.
    Any new techniques for this?
    Danny Winn replied 16 years, 8 months ago 2 Members · 3 Replies
  • Danny Winn
    January 15, 2010 at 1:22 am
    Hey Dave,
    I tried doing what was written in the link you provided but when I opened the upper layer Track Matte mode it only gave me options to select a different clip that was above the upper layer, not the layer below that it was duplicated from.
    Am I missing something here?
    Here’s what the link says:
    “• Duplicate the keyed footage, and turn off the upper layer.
    • Fool with the lower layer’s Keylight settings until it looks like the subject looks fine, but is over a grayish, washed-out chroma key background. It’ll take some doing, but you will have gotten it to the point where Keylight’s spill suppressor is working. That’s good, because the Keylight spill suppressor works darned well.
    • Open the Modes panel, and use the upper layer as an Alpha Matte for the lower layer. For more info, look up Track Mattes in AE Help.
    Poof! You’re done! You have a clean key, AND you have spill suppression.”
  • Curious Turtle
    January 15, 2010 at 3:37 pm
    Hi Danny,
    The track matte always looks to the layer above. If you’re following that guide, you should be working on the bottom layer, then take the alpha channel from your untouched key (the top layer).
    Another thing you can do instead of duping layers is turn Keylight to “Intermediate” and use a regular Spill Suppressor filter afterwards.
    Hope that helps,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
    Out Now – Film Wash Color Effects Vol. 3
    & Mocha training for AE & FCP
  • Danny Winn
    January 15, 2010 at 8:17 pm
    Very cool Ben, thanks I’ll try that;)
