Activity › Forums › Adobe After Effects › keylight artifacts
  • keylight artifacts
    Posted by John Wahoo on October 9, 2010 at 6:35 pm
    i´m working on some greenscreen shots, comparing different keyers and settings.Keylight is giving me some headaches. It does a really good job on the edges and for the despilling, but it also introduces horrible artifacts within the image. I tried different settings to avoid it, but it seems, that only switching the keyer to “intermediate result” gets rid of those artifacts.
    There doesn´t seem to be any information inside the image to justify such artefacts, the matte is clean it looks like there´s some problem in the despilling algorithm. One thing that improves the image is when I turn the replacement mode to “hardcolor”. Still you can see those artifacts, but it´s slightly better.
    Any idea what could cause this problem? I also tried primatte, which is doing a pretty good job, but not as good as primatte would do concerning the edges.
    Here a link to an image that should clarify the problem.
    https://audiovisual.at/download/keylight-problem.jpg
    footage was shot on a red cam.
    Thank you for any help
    John Wahoo replied 15 years, 11 months ago 35,872 Members · 1 Reply
  • John Wahoo
    October 10, 2010 at 2:59 pm
    i found out that there are some artifacts in the blue channel, which seemed to be created from the conversion of the files to the tif sequence i got. The problem is not in the raw files…
    just to let you know
