Activity › Forums › Adobe Premiere Pro › Keying/Premiere plug in? to fix overexposed background in interview
  • Keying/Premiere plug in? to fix overexposed background in interview
    Posted by David Dicanio on January 24, 2006 at 4:24 pm
    I did something rather stupid– put an interviewee in front of a window. The key light is nicely exposed, and stays nice throughout the interview, but the window behind is too bright. Sometimes it’s acceptable if the sun goes behind the clouds, but there are a few shots that go totally white.
    Someone suggested a 55mm After Effects Plug in from digital film tools. I don’t own After Effects, but may have to buy it. Does anyone know of a plug in for premiere that would help me key things or do some selective saturation with the background window?
    You can see frame grabs I did with the link below – “BJ” is the
    original shot / “BJ1” is a title designer fix / “BJ2” is using the
    Green Screen Key (darkens it a bit) / “BJ4” is where the sun gets
    strong and basically clips exposure / and “BJ3” is where I try to fix that
    with the title designer.
    https://daviddicanio.home.mindspring.com
    Any thoughts would be greatly , greatly appreciated.
    dave
    David Dicanio replied 20 years, 8 months ago 5 Members · 6 Replies
  • Jeff Brown
    January 24, 2006 at 4:57 pm
    Luminance key?
  • Tim Kolb
    January 24, 2006 at 5:00 pm
    I might try to grab a freeze of the curtains at the best exposed point where the talent’s head exposes the most curtain area…then try the multiply keyer…but if you don’t have PPro v2…the multiply keyer doesn’t work.
    …then you’ll need AE, which I’d prefer for this type of a fix anyway, personally.
    As an alternative, try a track matte. Put the video directly over itself on a higher track and turn off that track (in Ppro versions earlier than 2) and then put your curtain grabbed frame on another track. Key the curtains into the overexposed areas using “luma” on the matte setting. The only thing I might wonder about on this would be if you’ll end up with curtains keyed onto his head highlight…I suspect you might.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Mike Cohen
    January 24, 2006 at 5:51 pm
    this happened to us a couple years ago – we wound up buying the “re-shoot” plug-in from southwest airlines!
  • David Dicanio
    January 24, 2006 at 5:54 pm
    Don’t think we’ll try to reshoot it. I think there is a fix that’s better than traveling to reshoot it. I think the washed out shot is hopeless, unless it’s a great sound bite, but the blue curtains can be darkened a bit w/o effecting the face. I’m still reading posts on this, so hopefully there will be a fix that is reasonable. This is for a documentary, it was just one of the more important interviews. Thanks for the thoughts.
  • Dex Craig
    January 25, 2006 at 6:23 pm
    You might have to export a sequence of stills and create a track matte in Photoshop or your image editing package of choice. Tedious, yes, but without AE, it may be your only hope.
  • David Dicanio
    January 27, 2006 at 1:58 am
    I ended up buying the 55mm plug in from Digital Film Tools. I was amazed at the power of those plug-ins. I never realized there were such things to fix something like this. Naturally it would have been better to get the shot right first, but this plug in made it acceptable.
    The first is the original where the window, which was a nice blue with curtains, turned total white from the sun coming out stronger than when I started the interview.
    https://daviddicanio.home.mindspring.com/BJ55m-orig.bmp
    The second one is my fix. It looks a little dark on a computer mointor, but looks nice on my timeline monitor.
    https://daviddicanio.home.mindspring.com/BJ55mm-fix.bmp
    Just wanted to get back with folks.
