Activity › Forums › Blackmagic Design › Keying workflow with a decklink
Posted by Christian Coslar on April 29, 2006 at 10:56 amHey everyone,
IDeleted User replied 20 years, 5 months ago 2 Members · 2 Replies -
Christian Coslar
May 1, 2006 at 10:27 am7 moderators and no answer so far…?
Were my question too unprecise?
Too many questionmarks?
Hope not hehehe…
In another threat some one suggested recording to SheerVideo codec,
can a Decklink do this?
Also would keying benefit from HD aquisition, maybe recording 720p in SheerVideo?
If not SheerVideo, which other codecs would yield better quality than DVCpro50/100 and
still could be handled more easily than uncompressed comming from the Decklink?
I -
Deleted User
May 1, 2006 at 3:52 pmHello,
To answer your question,
1) Which BMD card will give me the best bang for the buck here?
I believe you would need a HDTV series Blackmagic card to work with the high definitions resoultions.
2) I use PP 2.0 for editing, can I use it for live capturing the key?
You can connect the camera and capture to the comouter you are just capturing live rather then from a pre-recorded tape.
3) Will I need a special hardware setup for SD uncompressed capuring, like a raid?
Yeah would need a sata drive set as raid stripe 0 to capture and playback the uncompressed sd clips.
4) will I later somehow benefit from the Decklink, besides I/O options?
The Decklinks are designed for a input and output board they just offer the I/O and allows you to connec to a broadcast video monitor to preview your work and high quality sound outputs.
I hope this helps?
Leo
