Activity Forums Apple Final Cut Pro Legacy Keying with separate hi con
  • Keying with separate hi con
    Posted by Slim Simon on June 14, 2005 at 7:53 pm
    Folks,
    I have a moving graphic (lower 3rd, let’s say) with a separate hi con. Two separate pieces of video. What’s the proceedure for keying this over a background video layer? Is there a way to marry the fill and hi con together into one file, so I can just drop it over whatever background video I want? (with rendering, of course). I’m doing a show with many of these elements, so I’d love to pre-build as much as I can, and limit the number of video tracks if I can.
    slim
    Slim Simon replied 21 years, 3 months ago 3 Members · 5 Replies
  • Matthew Brunn
    June 14, 2005 at 8:03 pm
    I would precompose your elements in LiveType, that way I just save as and change the names as I go.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Slim Simon
    June 14, 2005 at 8:07 pm
    In Live Type? How does that work? Can I marry the fill and hicon together into one video file?
    slim
  • Matthew Brunn
    June 14, 2005 at 8:30 pm
    As long as they have alpha channels you can directly import (under edit “place”) and composite them. When you do a save as, LiveType will reference the same files over and over. No need to make them one video clip, it leaves your options open for adding or subtracting elements later without re-compressing again. The .ipr LiveType file will render in your FCP time line, no need to render out of LiveType.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
  • Bouncing Account needs new email address
    June 14, 2005 at 8:49 pm
    Here’s how it works with multiple video layers:
    You can use any high-contrast image (a Title, a Photoshop image, a moving video clip, etc) to cut a HOLE (in it’s exact shape) and “Fill” it with other moving (or static) video… all “keyed over” another video track.
    V3: Fill clip. What you want to be “inside” the “hole(s)”. (Where the WHITE area of the V2 clip is.)
    – Select (highlight) THIS clip on V3, then:
    Modify (menu) > Composite Mode > Travel Matte – Luma
    V2: “Hole-cutter” clip or title
    V2 can be any HIGH-CONTRAST (B&W preferred) video or CG.
    V1: Background clip. Will be seen outside the “hole(s)”. (Where the BLACK area of the V2 clip is.)
    V1 can be a VIDEO CLIP or a MATTE COLOR.
    If you end up with the “reverse” of what you want, swap the clips on V1 and V3.
    Remember to change the settings (Modify (menu) > Composite Mode > Travel Matte – Luma) on the clip that is now on V3.
    You can move/expand/reposition the V2 clip or even use it as a custom “wipe”.
  • Slim Simon
    June 15, 2005 at 4:54 am
    I appreciate the responses. What I’m asking is: can I turn two clips (fill, and hi-con), into one clip: (fill, with embedded alpha), ala a tga frame.
    slim
