Activity › Forums › Adobe After Effects › keying with a real background (ie not blue, green)
  • keying with a real background (ie not blue, green)
    Posted by Jon Frickey on August 28, 2008 at 4:49 pm
    Hi there!
    Here is the problem and perhaps half of the solution:
    I’ve got a scene of my BACKGROUND, a street, plus a scene with a MOVING CAR INCLUDING THE BACKGROUND.
    I otta be possible to somehow key the car out of the background, in other words subtracting “background” from “car + background” and thus getting “car minus background”
    I’ve tried by laying the “background” layer over the “background + car” layer with the “difference” layer mode, receaving only black (where the background was) and the kind-of-silhouette of the car. However keying out the black in a new composition didn’t work, because the silhouette has too many colors, including lots of black. (then I was going to use this comp in a new comp as alpha layer mask for “car + background” comp).
    Hard to follow?
    I know.
    Can someone help? Thanks!
    Jon Frickey replied 18 years, 1 month ago 4 Members · 4 Replies
  • Justin Parker
    August 28, 2008 at 4:56 pm
    There is a Difference Matte filter in the Keying section that is used for this. It’s similar to using the layer mode method but gives you some more options such as Matching Tolerance, Matching Softness and Blur before difference
  • Tim Garber
    August 28, 2008 at 6:54 pm
    Naturally you’ll be working when that car passes behind your talent or other foreground elements. If small enough I’ve had luck using this method by simply offsetting the replacement layer a few frames when there was no lockdown.
  • Jimmy Doyle
    August 28, 2008 at 7:24 pm
    Is this what you are looking for:
    Rotoscoping in AE by Pete O’Connell
    https://library.creativecow.net/articles/oconnell_pete/roto.php
  • Jon Frickey
    August 29, 2008 at 5:40 pm
    Thanks for all the postings. I’ll give everything try!
