Activity › Forums › Apple Final Cut Pro Legacy › Keying with a border?
Posted by Irene Driessen on September 3, 2013 at 5:57 amHi, I’m trying to work out how to make a look like this: moving “cutouts” with a border, either the one from the keying bg or not. Is that at all possible without frame-based work?
https://youtu.be/jxMPelMfAL8 Example of the look I’d want to achieve.
I don’t know where to start my search :)…
Irene Driessen replied 12 years, 11 months ago 3 Members · 4 Replies -
Alan Okey
September 3, 2013 at 4:48 pmThis is fairly simple in a node-based compositor. The basic technique would involve creating a core matte and expanding it using a MinMax node.
Conduit is a great, inexpensive node-based compositing plugin for FCP. The DV Garage website has a ton of useful tutorials that will get you up to speed on node-based compositing.
https://www.dvgarage.com/conduit-2
The following video demonstrates creating a procedural garbage matte, but the technique used to expand the edges of the matte using a MinMax node is relevant to your question:
https://www.dvgarage.com/storage/conduit-2-samples/Conduit2_ProMatte_3.mov
Also see the push to white video:
https://www.dvgarage.com/storage/conduit-samples/conduit2_push2white.mov
You could shoot your talent on a green screen, then use Conduit to create an effect like what your video example demonstrates.
The newest new version of Conduit is PixelConduit, and there is a free version that has all of the functionality needed for most operations. I’m not sure that it works with FCP 7, however – the website says that it’s for FCP X and Motion 5.
https://pixelconduit.com/index.html
Mark Suszko
September 4, 2013 at 2:28 pmYou could import the video into photoshop as stills, with alpha channel, and apply the Stroke effect in Layer Styles. Makes the edge color and width selectable. I *think* you can do this in Apple Motion, for sure you can in AfterEffects.
Mark Suszko
September 4, 2013 at 5:01 pm
