Activity › Forums › Adobe After Effects › Keying Transparent Fabrics?
Posted by Lisa Tanner on March 24, 2016 at 6:28 pmI’m working on a project with a character in a sheer (gauzy) outfit on a green screen. Are we nuts or is this possible? I know it’s not ideal and I’m pushing for tests before the shoot.
Lisa Tanner replied 10 years, 6 months ago 2 Members · 5 Replies -
Kevin Camp
March 24, 2016 at 9:54 pmAndrew Devis has a tutorial series for multi-later keying that covers keying shear fabrics that may help you out.
https://library.creativecow.net/devis_andrew/Multi-Layer-Editing-1/1
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Lisa Tanner
March 24, 2016 at 10:00 pmHey, I’ve worked with that footage, but didn’t know it was part of a tutorial. Thanks!
Lisa Tanner
March 24, 2016 at 10:01 pmGotcha. Thanks so much for the tips. Will “well lit subject” still let us match the lighting of the location plates? I’m asking them to light the green screen separately for flatness.
Kevin Camp
March 24, 2016 at 10:36 pmthe screen will definitely be lit separately from the subject.
as for the lighting of the subject, your key light should reflect any obvious lighting in the plate, but after keying, you will likely need to make adjustments to the subject while you are compositing it with the plate.
here’s an older written tutorial, but you can find newer video tutorials out there:
https://library.creativecow.net/articles/coots_brendan/greenscreen.php
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
