Activity › Forums › Adobe After Effects › Keying the green screen with lot of shadows
  • Keying the green screen with lot of shadows
    Posted by Muaz Nikolic on July 24, 2018 at 3:40 pm
    Hello,
    I am having trouble to key the green screen because I have lot of shadows. Can someone give me advice what is the best way to key this footage.
    12576_greenkey.mp4.zip
    Also I am having a lot of noise in the part where the shadow is. What would be the best way to remove it because whene I key it out I get strange artefacts.
    Thank you all in advance
    Ivan Phang replied 8 years, 2 months ago 3 Members · 2 Replies
  • Steve Bentley
    July 24, 2018 at 5:17 pm
    It looks like the culprit is the blue channel. This is the problem with compressed footage being used as a source for the key, the compression adds noise to the noise already there from the camera.
    But the green channel is quite clean (this is why we use green screen whenever possible).
    So here’s a file without the usual standard keyer that produces a better result and keeps the shadows.
    Have a look and see if that does it for you. You will need to do a little work on the highlights and reflections, but these should be there so that you can pump color from the new background through them as though they are reflecting the environment.
    12577_greenkey.aep.zip
  • Ivan Phang
    August 2, 2018 at 8:52 am
    That happens often whenever the green/blue screen video isn’t clean enough for your software to intelligently autokey them. Under those circumstances, I will recommend masking them out manually or automatically if your software supports it. Good thing is this specific scene you’ve shown isn’t complex, shouldn’t be difficult to manually mask out the entire shot.
    Helping clients attract Eyeballs!
    https://luciddream-animation.com
