Activity Forums Adobe After Effects Keying Problem on intersecting edges
  • Keying Problem on intersecting edges
    Posted by Tyler Mcneill on September 2, 2019 at 3:51 pm
    Hey there,
    I have encoutered this problem dozends of times but I don’t really know if there is a name for this. The key itself looks ok, but where 2 people are intersecting you get this bright edge that travels along the intersections. (see image)
    13674_edgesschlrp.gif.zip
    Is there a clever way to get rid of this? The chokers just take away the edge even where it has to stay and if I start masking the effect it is veeery timeconsuming.
    Any ideas?
    Thanks very much in advance!
    Tyler Mcneill replied 6 years, 12 months ago 2 Members · 2 Replies
  • Rich Rubasch
    September 2, 2019 at 3:57 pm
    Not sure which keyer you are using but sometimes Edge Color Correction can help here.
    Also I sometimes pre process my green footage in a sub comp. I use Hue Saturation to boost only the green channel saturation and also sometimes add a denoiser. Then in the main comp I pick that now much more saturated green….this helps define the edges better.
    I almost always use Edge Color Correction in Keylight and I can make any slightly green or brighter edge areas match the shirt they are wearing or a background color etc to make a more convincing composite.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Tyler Mcneill
    September 25, 2019 at 10:01 am
    Hello Rich,
    sorry, but I totally forgot to thank you for your reply. I ended up using a mixture of your method and a bunch of edge correction tools and it worked way better than before.
    Thank you very much!
