Activity Forums Apple Motion Keying plugin for motion 3
  • Keying plugin for motion 3
    Posted by Zach Smith on May 24, 2007 at 12:30 am
    I have a project that we started to work on in motion 2 on a non intel machine. We used a plugin from DV Garage called DV Matte Pro, this plugin is not available for intel machines. The company has another plugin called DV Matte Blast for motion 2 which is universal but does not appear to work in motion 3. Does anybody know of a plugin that is comparable to this one that works in motion 3? This was the only plugin that I know of where you could have two different shades of green and it would average the two or something like that. All stock plugins and even third party plugins I have found will not key this footage correctly. HELP
    Taj Jackson replied 19 years, 3 months ago 5 Members · 6 Replies
  • Noah Kadner
    May 24, 2007 at 3:10 am
    I’d say key it in FCP with the DV Garage plugin or the Noise Industries one. I’m sure the one you use now will ultimately be updated for Motion 3 if feasible.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Doyle Rockwell
    May 24, 2007 at 1:28 pm
    Heya,
    I’m using dvMatte Blast in Motion 3, right now. What problem did you experience when trying it in version 3?
  • Rodereckjaynes
    May 24, 2007 at 6:09 pm
    Yes, I seem to be having the same problem. As soon as I apply the effect, the program immediately crashes…
  • Doyle Rockwell
    May 25, 2007 at 1:11 am
    Are you running the Universal Binary (Intel & PPC-friendly) version?
  • Rodereckjaynes
    May 25, 2007 at 1:33 am
    Yes,
    As a matter of fact, I tried it on my macbook pro and it worked, however, my main system is PPC.
    I think the UB side that works with the PPC is still the old version mashed with the upgrade.
    Very sad, my workaround is that I am keying on the macbook to animation alpha movies, then dragging them back to the tower. It’s a huge pain.
    Can prores include an alpha channel?
  • Taj Jackson
    May 27, 2007 at 5:06 pm
    For me, when I choose to view the foreground in the DVMatte Blast plugin, the foreground layer completely disappears on me. I downloaded the demo as well to check and it does the same thing as my retail version does.
    I am using Motion 3 and a 15′ 2.33 Macbook Pro
