Activity › Forums › Apple Final Cut Pro Legacy › Keying people wearing galasses
  • Keying people wearing galasses
    Posted by Ryan Lloyd on December 12, 2007 at 10:48 am
    Hi all just wondering if anyone can help.
    I have unwisely filmed someone against a green screen using chromatte who was wearing glasses. I am now keying the footage in Final Cut Pro and am having problems when the light occasionally reflects green on the lens of their glasses and I get little holes appearing in the middle of them for a second or two.
    I was just wondering if it was possible to create some sort of mask in FCP that I could place over the glasses so that the keying is not applied to that part of the footage.
    Or if anyone has any alternative suggestions as to get around this problem I would be very gratefull to hear them.
    Cheers all.
    Jeremy Garchow replied 18 years, 9 months ago 4 Members · 3 Replies
  • Rafael Amador
    December 12, 2007 at 12:22 pm
    You can try masking with FC. If you don’t get good results you can rotoscope in AE or Shake them export the mask and use it in FC.
    rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Jeff Greenberg
    December 12, 2007 at 4:37 pm
    You might want to consider a better keyer than the built in one. Try DVMatte from DV Garage.
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
  • Jeremy Garchow
    December 12, 2007 at 5:30 pm
    You can pull the key and get a good matte for the edges of your subject. Then you can simply place a white solid over the part with the holes (i.e. the glasses), nest those clips. Put the nest below a copy of the original clip, meaning nest is v2, original clip v3, bg clip v1 then use the matte layer (the nest) as a travel matte. It works great.
    Jeremy
