Activity Forums Adobe Premiere Pro Keying out green screen with a hotspot
  • Keying out green screen with a hotspot
    Posted by Ashley Davis on December 7, 2015 at 2:14 pm
    So I shot a green screen interview the other day and managed to mess up rule number 1 and got a hot spot lighting the screen.
    I had two cameras running – wide was fine but the close up has picked up a hot spot behind the actors face and I can’t seem to eliminate a small area. (see pic)
    https://tinypic.com/r/2zxtcm1/9
    I’m using the ultra key effect in Premiere and setting it to aggressive. This usually gets rid of the majority of green but the spot above was over exposed, I have played with highlights/shadows, tolerance, pedestal etc but I can only seem to reduce the area slightly but not completely.
    Any ideas? maybe something in AE?
    Ashley Davis replied 10 years, 9 months ago 4 Members · 6 Replies
  • Gabriel Coelho
    December 7, 2015 at 3:52 pm
    try to use the ultra key plugin
  • Ashley Davis
    December 7, 2015 at 4:01 pm
    I’m using ultra key
  • Ivan Myles
    December 7, 2015 at 4:53 pm
    It might be helpful to create and animate a garbage matte around the area, and then key out the hotspot colors.
  • Craig Howard
    December 8, 2015 at 1:45 am
    Add a second UltraKey Effect to the clip and see if you can pick it up in that.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Adobe CC2014 Suite, Resolve
    Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
  • Ashley Davis
    December 8, 2015 at 12:10 pm
    Considered that but think its too close to the subjects face
  • Ashley Davis
    December 8, 2015 at 12:17 pm
    I did try this initially but had another go and has just about sorted it with the help of a bit of mask as well. Thanks, hopefully that’ll do!
    This has taught me a lesson about green screens!
