Activity Forums Adobe After Effects Keying out background
  • Keying out background
    Posted by Brent Myers on November 10, 2005 at 7:05 pm
    When keying out the background color I have a few areas on a man’s shirt that were also keyed out and now have the new background color. Is there anyway to use “paint’ to restore the opacity of the keyed out part of the shirt to 100 per cent?
    Tony Kloiber replied 20 years, 9 months ago 3 Members · 2 Replies
  • Yussef Cole
    November 10, 2005 at 7:57 pm
    Before you do something that drastic and time consuming, i’d recommend going into AE’s “keylight” effect and messing around with tolerance levels. That effect can really accomplish somethings that simpler ones simply cannot.
  • Tony Kloiber
    November 10, 2005 at 8:52 pm
    If there is no way to pull a clean key with out losing some of the shirt, and the hole is not at the edge, you can simply add another copy of the footage layer to your comp and mask around the problem area. Feather and color correct to match and your set.
    If his edges move pass the mask then you could track his movement apply the track to a solid layer draw the mask as before put this solid layer above a copy of the original footage and use a tracking matte to reveal only the problem area. (apply tracking data directly to a mask would be nice – hint, hint)
    So long as the masked area does not cross his edges you need not worry about masking or painting the exact hole.
    TonyTony
