Activity Forums Adobe After Effects keying out a black background?
  • keying out a black background?
    Posted by Jon Iverson on July 1, 2009 at 12:40 pm
    I have a moving object (bird) that I want to isolate from a background that it totally black. After reading about keylight, I decided to try it. However, when I use the dropper to click on the black background, nothing appears to be happening. “Status” shows all white with nothing keyed out. The goal is to remove the black background and replace it with an image. I’ve tried adjusting all of the parameters in keylight as recommended, but also to no avail.
    Any help would be greatly appreciated.
    Thanks in advance,
    Jon
    Tom Scott replied 17 years, 2 months ago 6 Members · 5 Replies
  • David Bogie
    July 1, 2009 at 2:31 pm
    Keylight is a chromakeyer. You want to use one of the linear keyers since black has little o no chroma information.
    bogiesan
  • Anita Sancha
    July 1, 2009 at 2:32 pm
    Hi…
    I’m no expert, but I use keylight a lot, just in case you are doing something odd this was the best tutorial video I found on it.
    I also have got into the perhaps unnecessary habit of making my comp background a bright color, so I then know its not black/grey/white. It helps me not to get confused with the black/white status option if I am tired and part of it really has gone transparent.
    https://www.adobe.com/designcenter/video_workshop/?id=vid0229
    Cheers
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
  • Michael Szalapski
    July 1, 2009 at 2:37 pm
    Try one of the luma keyers available with AE or you could try Unmult, which is a free plugin originally intended to do transparency for lens flares on black.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Reiner
    July 2, 2009 at 2:00 pm
    “and you’ll learn about frame-by-frame animation of multiple masks.”
    ha
    Dave, I am a long-time fan of your posts. My dream is to one day be zinged.
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
  • Tom Scott
    July 3, 2009 at 5:02 am
    [Jon Iverson] “However, when I use the dropper to click on the black background, nothing appears to be happening. “Status” shows all white with nothing keyed out.”
    Are you sure the black is actually black, and not an alpha channel? Have you tried toggling the switch for the transparency checker-box pattern?
    DISCLAIMER: The contents of this post are based primarily on the opinions/understanding of the author. However, commonly known facts may also be included, when relevant.
