Activity › Forums › Adobe After Effects › Keying, Layers and 3D Glasses
  • Keying, Layers and 3D Glasses
    Posted by Bernie Bernando on July 2, 2009 at 9:38 pm
    Hey everyone…
    I am shooting a traditional anaglyph 3D short film (red/cyan glasses).
    However, I am trying to shoot the majority of it on a green screen
    with the intention of using multiple layers to control the amount of depth within each shot. I’m using AE CS3 on a Mac to composite.
    I’ve pre-composed my left and right footages and key’ed them out using Keylight. Now using the 3D Glasses effect in a new comp, I’ve loaded in the L and R pre-comps into it and it doesn’t seem to work. The 3D effect works, but i think the 3D glasses effect doesn’t incorporate the alpha channel into its calcualtion (or whatever). It creates the effect with the entire frame and the keyed out portion of the frame is back in black (ie. no transparency).
    Now, i’ve also tried rendering each L and R footage out as an image sequence with the alpha still intact… but alas, that technique gives the same result. I really need some help! anyone? anyone? Bueller? Bueller?
    .bernie:
    b.easy.nando
    Ron Weaver replied 14 years, 5 months ago 2 Members · 1 Reply
  • Ron Weaver
    May 4, 2012 at 1:48 pm
    I am having the same problems. The alpha channel turns black apon adding the 3D Glasses effect. Although we are 3 years later, maybe you found a solution or a workaround that would help me out.- I would really appreciate it!
