Activity Forums Adobe After Effects Keying keylight
  • Keying keylight
    Posted by Lumpynifkin on October 7, 2007 at 2:40 pm
    Really two questions here. I have green screen footage for a music video that i chopped with non green screen footage. I did this in premier then exported the whole video to after effects. I don’t know how to only keylight the green screen footage. I can key frame each of the settings but not the effect as a whole. 2nd question, does this seem the propper way to do this. Meaning with the import from premier.
    Benjamin Eshagpoor replied 18 years, 11 months ago 4 Members · 3 Replies
  • Aharon Rabinowitz
    October 7, 2007 at 5:24 pm
    I can’t think of a good reason to do it this way. Is there a reason you are editing everything together first?
    It makes more sense to key and composite each shot separately, and then to edit them together after they have been composited.
    So, bring the green screen footage into AE – key it out – composite it with the backgrounds and effects you want to use and then bring the clips into your video editor and edit the shots with your regular non-effects shots.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Eric Goldstein
    October 7, 2007 at 6:34 pm
    Just to eloborate: I usually edit to get my greenscreen or effects shots to their final length – so I’m not doing more effects work than necessary. I then export my effects shots individually at their edited length and import them into AE. Once effect are completed, I render them and bring them back to my editing program.
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
  • Benjamin Eshagpoor
    October 8, 2007 at 12:29 am
    I do the same thing as Eric, but on occasion, I have been known to leave some handles on the greenscreen clips in my editing timeline (if I have dissolves or transition effects in my timeline that require the extra handles).
    I use Final Cut to edit, and since there’s no way to rountrip my files to AE and back (at least not that I’m aware of), I find this to be the best overall solution, but it can be a bit cumbersome when you’re editing to music or SFX and you have a LOT of edit points that leave you with a lot clips to work with.
    Ben Eshagpoor
    Paragon Entertainment
    beshagpoor@paragon-ent.net
    beshagpoor@gmail.com
