Activity › Forums › Boris FX › Keying in FX
  • Keying in FX
    Posted by Michael Mohr on January 17, 2007 at 3:42 pm
    I’m using FX 8 in PPro 2. I want to use a dissolve effect between 2 items with alpha channels on video track 2 and have that dissolve keyed over what is on video track 1. It looks correct in the FX window but when I go back to PPro it’s not keyed. After I apply the dissolve effect (blur dissolve in this case) what do I need to do in order to get this to key?
    Peter Mcauley replied 19 years, 8 months ago 2 Members · 1 Reply
  • Peter Mcauley
    January 23, 2007 at 6:31 pm
    HI Michael,
    It’s a little difficult to know what is going on with the problematic effect without having a copy of the effect settings that you are using in FX here to look at. The effect that you are describing should have worked – if it looked right in the BFX UI then it should have rendered correctly in P Pro.
    Can you please send us an email at support@borisfx.com describing the problem and including a copy of the settings file so that we can work on this together? We would like to try to resolve the issue for you.
    Cheers,
    Peter.
