Activity Forums Adobe After Effects Keying HDV
  • Keying HDV
    Posted by Kevin Herrin on May 17, 2006 at 9:52 pm
    I am keying hdv video with fairly decent results. My problem is when I drop hdv into a sd comp the video get really soft. I have applied the sharpen filter which works ok, I would rather not if don’t have to. Any ideas as to why I would loose the image quality? What I am doing now looks worse than if I shot something in sd and keyed it. Would I get better results downconverting thru the our Kona 2 card and then keying?
    thanks
    Kevin
    Brock_r replied 20 years, 4 months ago 3 Members · 3 Replies
  • Andrew Kramer
    May 17, 2006 at 10:41 pm
    What size are you making the video. 50 percent? this number would be best for subpixel sampling.
  • Kevin Herrin
    May 18, 2006 at 12:32 pm
    I am scaling the video down to about 65 to 70%.
    Kevin
  • Brock_r
    May 20, 2006 at 3:34 am
    have you trid exporting the footage? I’m assuming you are working with 16:9 footage, so it might look squished in AE, making it look blurry, but after export it might look fine
