Activity › Forums › Live Events & Streaming › Keying graphics over motion background using Keynote
  • Keying graphics over motion background using Keynote
    Posted by Jason Shane on June 24, 2016 at 4:17 pm
    I am trying to figure out the best way to key name titles/graphics over a motion background for a live event.
    I have a switcher that can key, a media server as a source for backgrounds, mac computer with keynote for the graphics, but the problem is the keying. Keynote does not have an “alpha” channel as far as I know, so you have to choose a color as a background and then key that out. Some of the effects just look really bad, regardless of the chroma color chosen. Do I just need to avoid these effects or is there a better way to go about this?
    In addition to this, keynote glitches every time you change slides because the looping motion background stops and reloads. Some of the show lends itself to a long “build” where I can put it all in one slide, but other parts are just too complex and I need to be able to change slides, thus making the background stop and reload (causing a visual glitch).
    I have considered making custom backgrounds in after effects where the motion slowly comes to a stop so when the slide changes, there is not a jolt/glitch look on screen when changing slides.
    I am open to suggestions for other software, but would prefer to stick with keynote since a lot of it is already built. Feel free to give $$$ costly options too, because this is a big show and I want it to look great.
    Thank you all.
    Thomas Leong replied 10 years, 3 months ago 6 Members · 12 Replies
  • 12 Replies
  • Mark Suszko
    June 27, 2016 at 8:12 pm
    You’re asking Keynote to be something it wasn’t designed to be: a proper TV Character Generation system. If that’s what you’re limited to using, break out the motion backs, play them off of a non-stopping or seamless looping source that feeds the switcher, and make the Keynote text appear over a custom “superblack” background, then use luminance keying to lay in the keys.
  • Jason Shane
    June 27, 2016 at 8:20 pm
    I was afraid that was the only answer when sticking with keynote. Maybe for next year I can use different hardware/software. Do you know of any that could be built weeks ahead of time (including effects) and ready for use on site? That kind of removes the Viz from the conversation… I was thinking something else that has an alpha channel and can be built off site.
    We have tried the luma key on black and most of the effects do not work well. Since we are tied down to some of these effects, at least for this year, I am working on making looping motion backdrops that come to a slow stop. This seems reasonable and looks pretty good… but not ideal. At least you can switch slides and there is not a visible shift and then the motion just starts up again.
    Thank you for your response.
  • Mark Suszko
    June 27, 2016 at 10:32 pm
    I empathize, but I’m not up to date on software CG options. We got a version of Expression, which seemed to have everything one could want, and everybody in the shop hates, hates, hates it. Not because it isn’t capable, but because operating it is too darned complicated. There has to be a simpler alternative out there that runs on contemporary platforms, but I didn’t go to NAB and am not up to date on them.
    Knew a guy that swore by SCALA, don’t know if that’s still a thing.
  • Jim Brown
    June 28, 2016 at 12:47 pm
    Take a look at Pro Presenter from Renewed Vision. While designed for churches we use it extensively in corporate work. Very solid product and very reasonable.
    Jim Brown
    M&M ProductionsUSA
  • Walter Soyka
    June 28, 2016 at 12:48 pm
    What media server are you using? Can you do the CG there?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Matt Townley
    June 30, 2016 at 9:00 pm
    Take a look at CasparCG. It can do everything you are looking for and has various pricing options.
  • Jason Shane
    June 30, 2016 at 10:06 pm
    Thank you for the reply. We considered that but it was shot down for some reason. I will revisit it.
  • Jason Shane
    June 30, 2016 at 10:07 pm
    Spyder. Which is contracted out and we need to build graphics weeks ahead of time for approvals, etc.
    I am not familiar with using the Spyder for graphics, or if it even does it.
    Thanks for the reply.
  • Jason Shane
    June 30, 2016 at 10:09 pm
    I will look into it. Thank you.
    My main concern is being able to build graphics (there are A LOT of them) ahead of time and able to show them to client with animations for approvals.
  • Walter Soyka
    July 1, 2016 at 10:43 am
    [Jason Shane] “I am not familiar with using the Spyder for graphics, or if it even does it.”
    Spyder is a multi-destination switcher, not a media server. Something needs to feed the Spyder the motion media backgrounds as a video signal (DVI, HD-SDI, etc.). Some media servers support live text, and any server would allow you to use pre-rendered animations (with alpha), if you can pre-produce your graphics.
    Walter Soyka
