Activity › Forums › Adobe After Effects › Keying – Despill Bias
Posted by Marc Lucas on December 30, 2013 at 10:33 pmWhen I use the Despill Bias colour picker and click on the skin tone it makes the footage/talent noisy. Why is that?
Marc Lucas replied 12 years, 8 months ago 63,692 Members · 6 Replies -
Marc Lucas
January 2, 2014 at 10:41 amThanks for the comments Dave.
I will have a look at your suggestions. One thing I did notice was that if I pulled the key initially without using the Keylight Despill the key is actually quite good and the talent looks ok but as I have mentioned it goers wrong when using the built in Despill, however, if I use a separate Despill plugin I don’t seem top get the aforementioned grain after applying?
In relation to the green BG being to hot what kind of levels do the green BG need to be for future reference, thanks
Marc Lucas
January 2, 2014 at 5:23 pmJust to follow on I thought I’d upload a screen grab of the Colour Finesse screen of the talent in front of the green screen. The green looks quite even but only at around 40-50% so is that where you suggest the green screen should be brighter up to 70ish?
https://dl.dropboxusercontent.com/u/2003727/Screen%20Shot.png
Marc Lucas
January 3, 2014 at 11:04 amI’m not having problems really I hope thats not how things came across. The only hiccup I had was when I applied the Despill function in Keylight but looking back I really didn’t need to use it on the footage. Appreciate your comments and help though.
Marc Lucas
January 6, 2014 at 1:04 pmHi Dave
Really not sure whats going on here I’ve been playing with the key again. The original footage is fine no noise whatsoever. When I go to pull the key and apply minimal key light settings I get noise on her head.
settings
https://dl.dropboxusercontent.com/u/2003727/Screen%20Shot%202014-01-06%20at%2012.28.52.png
Vid
https://dl.dropboxusercontent.com/u/2003727/test3.mov.zip
Marc Lucas
January 6, 2014 at 1:33 pmto update heres a screen grab of the Status showing green
https://dl.dropboxusercontent.com/u/2003727/Screen%20Shot%202014-01-06%20at%2013.32.17.png
Marc Lucas
January 6, 2014 at 5:17 pmI’ve since had a go with that and worked way better:-) Just sorting out the edges now, might have to do the head and body in two separate sections due to the hair not sitting right.
