Activity Forums Adobe After Effects Keying based on hue and saturation
  • Keying based on hue and saturation
    Posted by Chris Orcfilm on December 10, 2017 at 11:12 pm
    Hi all, likely overlooking the obvious here but hitting dead ends. I need to key the attached:
    Keying the blue saturated area from the grey unsaturated area regardless of lightness.
    Any suggestions are appreciated.
    BC Canada
    Simon Ubsdell replied 8 years, 9 months ago 2 Members · 1 Reply
  • Simon Ubsdell
    December 11, 2017 at 6:58 pm
    [Chris Orcfilm] “Keying the blue saturated area from the grey unsaturated area regardless of lightness.”
    Your problem is that despite what it may look like to the naked eye, your image is almost entirely blue.
    Here’s a map of where the blue is greater than either red or green. Only the few black areas are where another channel is higher than blue.
    Even a very good HSV keyer isn’t going to be able to identify the areas you are seeing as “not blue”. And Ae doesn’t have a good HSV keyer.
    Edit: That said, you might want to try tweaking the image slightly with a Curves before applying the keyer, reducing the blue in the highlights. You can start to get a more reasonable result that way.
    Simon Ubsdell
    tokyo productions
    hawaiki
