Activity Forums Panasonic Cameras Keying and resolution
  • Keying and resolution
    Posted by Justyot on January 24, 2007 at 12:23 am
    I am working in a 720/24p workflow and I would like to shoot some footage that will be keyed. Would you recommend shooting the footage at the 1080/24p setting and down rez to 720/24p for more information? Are there any inherent problems with this workflow, or any additional tips one could give that work well with the hvx? Thank you.
    Barry Green replied 19 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    January 24, 2007 at 12:41 am
    I’d shoot in the same format you are editing. I have gotten great keys off 720p24 footage. Make sure the key is nice and even.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Barry Green
    January 24, 2007 at 5:19 am
    I would shoot 1080/24p for any keying situation. You get a tad more detail, but you get effectively quite lower compression, which gives you a cleaner image to start from.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Arcadian
    January 29, 2007 at 9:35 pm
    Barry,
    Aren’t both 720P and 1080P(i) 100mb/s? How do you figure that the 1080/24p footage would have “effectively quite lower compression?” I would think it would have effectively MORE compression… over a larger canvas. But I also know that you’re quite the expert on these things… so I’d just like to understand your conclusion.
    Kyle
  • Barry Green
    January 30, 2007 at 9:11 pm
    You have about 20% more detail in the 1080 picture, but 100% more pixels to record it in. So a lot more bandwidth allocated per pixel.
    It’s true that in both 1080 and 720, a 6.7:1 compression ratio is used. But the thing is, in 1080 mode, there’s twice as much bandwidth per frame, but not twice as much detail. So the 1080 mode places a lot less stress on the codec than the 720 mode does. This results in milder compression artifacts etc; it effectively gives you around 80% more bandwidth.
