Activity › Forums › Adobe After Effects › Keying and light wrap in AE
  • Keying and light wrap in AE
    Posted by Vince Becquiot on February 12, 2008 at 7:42 pm
    Can someone recommend a way to create soft reflections on the edges of a keyed foreground object based a background, thus selling a shot (those familiar with Primatte light wrap will know where I’m coming from).
    Vince
    Vince Becquiot replied 18 years, 7 months ago 3 Members · 4 Replies
  • Erik Pontius
    February 12, 2008 at 7:54 pm
    You might check the tutorials section…like this one:
    https://library.creativecow.net/articles/dewar_john/light_spill.php
  • Darby Edelen
    February 12, 2008 at 7:59 pm
    In my experience, this will generally require at least 4 comps, one for the foreground (keyed) element, one for the background, one for the lightwrap and one for the composite.
    Place the background comp in the lightwrap comp, then place 2 copies of the foreground comp above this. Change the blending mode of the lower of the 2 foreground layers to ‘Silhouette Alpha’ and change the blending mode of the upper to ‘Stencil Alpha.’ Now apply a Box Blur to the middle layer (the ‘Silhouette Alpha’ layer) with at least 3 iterations and a radius of your choosing. I usually blur the background a bit as well so that the lightwrap will be more ambient (fewer details).
    That’s all the hard work. Next I usually just drop this lightwrap comp above my foreground and background comps in the composite comp and change the mode to ‘Add.’
    The benefit of using pre-comps for this workflow is that you can switch out the footage in either the foreground or background pre-comp and everything updates accordingly!
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Darby Edelen
    February 12, 2008 at 8:49 pm
    [Dave LaRonde] “The one drawback is that you can’t use 3D layers & lights”
    Just a note, I often use 3D layers (and sometimes lights) with my method. Although it may complicate things slightly depending on your requirements.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Vince Becquiot
    February 12, 2008 at 11:53 pm
    Thanks guys, this is starting to look very good. Now let’s hope the client doesn’t decide to go with a black background 🙂
    Vince
