Activity Forums Adobe After Effects Keying an object using a matt??
  • Keying an object using a matt??
    Posted by Adam Koubek on October 10, 2011 at 1:03 am
    I’ve seen this done but can’t for the life of me figure out how it’s done. If I have a stable footage, where only the object I want to key out is moving, can I somehow use the still image of the background as a matt to key out the moving object? The footage has a green screen but it’s not lit well enough to key. I’d appreciate any help, thank you.
    -Nack-
    Adam Koubek replied 14 years, 11 months ago 2 Members · 2 Replies
  • Ben G unguren
    October 10, 2011 at 2:53 am
    It’s called a “Difference Matte” and is a filter in AE. You’ll need a still image of your video to use as the matte to calculate the difference. I usually use a precomp and time remap with a single keyframe where the object I’m keying out isn’t there.
    Note that Difference Matte isn’t going to get you as nice a result as something like Keylight usually will. But give it a go at any rate, see how it looks….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adam Koubek
    October 10, 2011 at 5:34 am
    Thanks a bunch. I’m just trying to avoid a whole bunch of roto and this should absolutely help out. Thanks again.
    -Nack-
