Activity › Forums › Adobe After Effects › Keying
Keying
Posted by Marc Lucas on December 30, 2013 at 10:17 pmWhy do you get a black line like in the pic when pulling a key with Keylight 1.2? It has happened more on one side than the other.
Using XDCAM from an EX1
Steve Brame replied 12 years, 7 months ago 4 Members · 7 Replies -
Jerry Wise
December 30, 2013 at 10:52 pmI get the same dam line all the time. it’s the camera setting…too much enhancement. shoot the same thing with your still camera and it won’t be there.
Marc Lucas
December 30, 2013 at 10:57 pmThe side it happened on was the side the back light was on so yes something to do with how the light is interacting with the footage and green screen when trying to key
Steve Brame
December 30, 2013 at 11:09 pmUsually thought of as being caused by the camera applying a sharpness filter. If you can, turn that off. Andrew Devis explains how to deal with it in this series…
https://library.creativecow.net/devis_andrew/Multi-Layer-Editing-1/1
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Darby Edelen
January 2, 2014 at 5:51 am[Marc Lucas] “The side it happened on was the side the back light was on so yes something to do with how the light is interacting with the footage and green screen when trying to key”
That makes sense.
The way sharpening filters generally work is by increasing contrast along edges. With your camera’s edge enhancement filter on it will see a bright white edge on your talent and say to itself “Aha! I should put a dark edge just on the other side of that light edge! My master shall be so pleased…”
Silly camera. Bottom line is that checking to make sure any sharpening filters are turned off in the camera before shooting green screen is essential.
You might be able to rescue this with some extremely clever blend modes/channel shifting/grading/roto or with the decidedly less clever Refine Matte effect. I’ve used it and it works really well sometimes, but if it doesn’t you’ve got to move on to other options.
Darby Edelen
Marc Lucas
January 2, 2014 at 10:36 amThanks for the replies. I have seen the Andrew’s tuts and will have a go with his workflow and also have a look at the camera settings for the future.
Marc Lucas
January 27, 2014 at 8:34 pmThere isn’t a Sharpness filter on an EX1 so how would I turn it off??
Steve Brame
January 27, 2014 at 9:01 pmThere is! It’s the ‘Detail’ setting. Turn it off. It’s in the ‘Picture Profile’ menu.
Steve Brame
