Activity Forums Boris FX Keyframming Problem
  • Keyframming Problem
    Posted by John Watts on June 1, 2009 at 7:15 pm
    Am using Boris BCC 4.2.2 on Avid MC 2.8.1, PC.
    Keyframing is not functioning correctly. Any parameter change I make gets applied to all keyframes in effect instead of the 1 keyframe I have selected. Hummm. So I found this problem is not new here on the forum but don’t see a resolution. I need to fix this without buying an upgrade today if that is possible…(please don’t laugh). Thanks
    John Watts
    Matt Mullen replied 17 years, 3 months ago 2 Members · 3 Replies
  • Matt Mullen
    June 1, 2009 at 7:22 pm
    John,
    This issue here may be that the parameter is not actaully getting keyframed.
    For some reason the default in Avid is to add a keyframe to active groups.
    If you right click the add keyframe button in the effect editor you should be able to set it to all parameters or active paramater and then add the keyframes you need. with the adjustments.
    Another way around this is to use the AVX 1.5 version of the plug.
    If this does not help let us know which effect and parameters you are trying to keyframe.
  • Matt Mullen
    June 1, 2009 at 7:43 pm
    No problem…as you stated in your first post, you are not the first person to be confused over this set-up
  • John Watts
    June 1, 2009 at 7:54 pm
    Problem resolved. Appreciate it much. ESTO…Equipment Smarter Than Operator…
    John Watts
