Activity Forums Apple Final Cut Pro Keyframing without any ramp
  • Keyframing without any ramp
    Posted by David Mayer on December 10, 2023 at 9:14 pm
    I am setting 2 position values to make a clip move using Transform. The options are smooth or linear. Linear is supposed to go from the start value to the end value directly, with no ramp on either end – just a straight line. But instead, it only lessens the same ramp used by the “smooth” setting.
    By “ramp” I mean it gets up to speed gradually at the start and slows down for the end.
    How to get rid of the ramp altogether?
    Ben Balser replied 2 years, 9 months ago 2 Members · 1 Reply
  • Ben Balser
    December 13, 2023 at 12:02 pm
    Can you post an example? I’ve not seen this issue before.
