Activity Forums Adobe After Effects keyframing “wiggle”… possible?
  • keyframing “wiggle”… possible?
    Posted by Mike Derk on December 13, 2007 at 5:47 am
    Hey,
    I’m getting the general impression that one either uses keyframes or one uses expressions to and an effect to a layer property.
    I’m using wiggle to get some random motion, and I want it to be adjustable: more here, less here, more again. But leafing through the manual seems to indicate that you have to set wiggle up and then let it go.
    Is there a way to make it adjustable?
    Am I going to have to learn to use variables, as it “var AmountToWiggle=…”?
    Here’s the thing: I know that when the object has a high Y-coordinate, I want no wiggle, but a low Y-coordinate means wiggle, so I actually have something to “link” it to.
    Mike
    Mike Derk replied 18 years, 9 months ago 2 Members · 2 Replies
  • Mike Clasby
    December 13, 2007 at 5:04 pm
    Here is a walk through on using a slider to control wiggle:
    https://forums.creativecow.net/readpost/227/8953
    Forgive the typos in the earlier post, please.
  • Mike Derk
    December 13, 2007 at 8:21 pm
    Thanks. Now I’m going to try to use Dan’s marker expression and do a lot of work to accomplish something I could do more easily, haha.
