Activity Forums Adobe After Effects Expressions keyframing the toggle on of an expression
  • keyframing the toggle on of an expression
    Posted by Richard Altman on May 19, 2009 at 7:56 pm
    is it possible to make a basic expression wiggle(2,340) and that makes it move crazy and thats great, but i’d initially for a few moments not have any movement then have the crazy movement the expression does. Can you keyframe the enabling of the expression on and off?
    thanks
    Richard Altman replied 17 years, 3 months ago 3 Members · 3 Replies
  • Eric Sanderson
    May 19, 2009 at 10:24 pm
    Well you could write an if/else statement with a checkbox…but an easier and just as effective way would be to just expression pickwhip your values to an expression slider…then just keyframe the slider.
    if you dont know slider is under. “effect”,”expression controls” “Slider Control”. Then highlight your “340” and whip it to the slider value.
  • Todd Kopriva
    May 20, 2009 at 2:51 pm
    In addition to the way that Eric describes, there are a couple of examples in After Effects Help (courtesy of Dan Ebberts) that show a couple of other ways to approach this, either by triggering on keyframes or markers or triggering on specific times:
    “Expression example: Animate scale at each layer marker”
    “Expression example: Start or stop a wiggle at a specific time”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Richard Altman
    May 20, 2009 at 4:09 pm
    thank you for the response, i am going to try that right now, it seems very clear, which for me is important. thanks again.
