Activity Forums Adobe After Effects Keyframing strangeness
  • Keyframing strangeness
    Posted by Ben Trahair on October 19, 2006 at 11:52 pm
    Hi all,
    I’ve been having a key framing problem lately where I set up 3 keyframes on a 3d layer moving in z space – one at 23400, one at 2720 and the last at 1837. Im using straight linear keyframes. Just before the final keyframe (between 2720 and 1837) the layer moves back and for a few frames and then forward to the final keyframe position. I know that there is something fundamental I am missing, because I have never understood why this has occured when it has and tried to find creative ways around it.
    I’ve checked to make sure there are no hidden keyframes next to other ones and am stumped
    Any ideas?
    Using After effects 6.5 and 7 on pc, Pal DV comp 1.42 pixel aspect ration.
    Cheers
    Ben
    Ben Trahair replied 19 years, 11 months ago 4 Members · 4 Replies
  • Julian Sixx
    October 20, 2006 at 4:07 am
    Hi
    this might help=>
    go to Keyframe Interpolation and change under Spatial interpolation from Bezier to linear
  • Mylenium
    October 20, 2006 at 6:00 am
    Make sure both your spatial and temporal interpolation are linear. They are separate properties in AE and making just one of them linear won’t work and result in the behavior you describe.
    Mylenium
    [Pour Myl
  • Aharon Rabinowitz
    October 20, 2006 at 7:55 pm
    Ben, would you be willing to send me the file? I’m doing a tutorial on correcting the boomerang effect, and want to see your particular issue.
    As long as it’s less than a few meg, You can zip it up and email it to me at info(at)pillusionfusion.com.
    Thanks.
    Aharon
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Ben Trahair
    October 21, 2006 at 12:07 am
    Thats it! Under keyframe interpolation temporal was linear and spatial was autobezier.
    Thanks for the tip!
    Ben
