Activity Forums Apple Final Cut Pro Keyframing Problem
  • Keyframing Problem
    Posted by Harry Katz on February 19, 2016 at 8:09 pm
    I am having trouble keyframing when zooming and panning. About 15 seconds into the clip I want to start the zoom and pan, and end 9 seconds later. I put in the first key at 15 seconds, at 100%, showing both subjects, and the second key 9 seconds later at 150% and centering one of the subjects.
    I can’t prevent the clip from sliding off the the left then back as the keyframing progresses.
    Any ideas?
    Thanks.
    Harry
    https://youtu.be/5ANpXzPYHLo
    Harry Katz
    harrykatz1@me.com
    Fedor Von hengstenberg replied 10 years, 7 months ago 4 Members · 3 Replies
  • Scott Witthaus
    February 19, 2016 at 9:10 pm
    Did you open the video animation on the clip in the timeline to see if there are any “rogue” keyframes that accidentally were added?
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • David Mathis
    February 20, 2016 at 12:28 am
    One thing I love about Final Cut is those sneaky little keyframes that appear from the deep, cold, dark abyss.
  • Fedor Von hengstenberg
    February 22, 2016 at 2:19 pm
    Harry, your problem is most likely due to the fact that you did not change the keyframe interpolation from default smooth to linear. In order to do this, click the icon at the lower left of your canvas window. Then the transformation keyframes should become visible on screen. Right or control click on them and set them to linear. This should alter the behavior of your transformation and solve the problem. BTW, I have not yet understood why linear is not the default option, but what do I know?
