Activity › Forums › Apple Final Cut Pro Legacy › Keyframing Hi-Res stills
  • Keyframing Hi-Res stills
    Posted by Kerry Villamil on December 18, 2008 at 8:27 pm
    Hello,
    I am keying framing movements on some Hi-res Stills. Unfortunately, the movement results in some distortion in detailed areas of the pictures.
    For example, a there is a tree in the background against a cloudy sky and there are all these lines that appear through the tree.
    How can I get rid of this?
    Thanks in advance!
    Curious Turtle replied 17 years, 9 months ago 2 Members · 1 Reply
  • Curious Turtle
    December 19, 2008 at 6:42 am
    Put a small blur on your still, and that should help. A Flicker Fixer will probably do you. Also, check that your render settings are set correcly in Sequence Settings (Cmd-0). See if turning the Motion Filter Quality to Best helps.
    Another thing is to ask yourself whether you need such a big still. If you’re not keyframing your scale to 100% on a particular still, you can happily use a smaller version. Simply scale it down a bit in Photoshop prior to importing in to FCP.
    All the best,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
