Activity › Forums › Adobe After Effects › keyframing expressions?
  • keyframing expressions?
    Posted by Benjamin Tubb on January 14, 2008 at 2:49 am
    I already asked this in the expressions forum, but no luck.
    Is there a way to keyframe expressions with hold keyframes? Like, Use one expression until frame X, and after frame X begin using a totally different expression?
    Any help is appreciated.
    Ben
    “Of course, I could be wrong. In fact, I’m probably wrong.”
    Benjamin Tubb replied 18 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Chad Gilmour
    January 14, 2008 at 4:09 am
    I’m not sure, I’m thinking no, but I basically use expressions pickwhipping abilities and not much more than that.
    A work around I’d sugest is maybe moving the playhead to where you want the layer to “change” expressions and pressing ctl/cmd+shift+D which will duplicate your layer and split it at the point of the playhead, then I would change the expression for the newly created layer.
    It’s a very fast and efficient way to do stuff similiar to what your describing.
  • Benjamin Tubb
    January 14, 2008 at 5:37 am
    Nah, that won’t work for what I’m doing. I have the corner pin effect on Layer 1. I need one of it’s corners to track a tracking point up to a certain amount of time, and then change to a different tracking point. And do it again, and again… Thanks though…
  • Jerzy Drozda jr
    January 14, 2008 at 11:17 am
    sure you can:
    if((0 < time) && (time<10)){ // first expression } else { // second expression } for the first 10 seconds execute first expression, then use the second one.
    maltaannon.com – Free After Effects Video Tutorials and more
  • Benjamin Tubb
    January 14, 2008 at 2:05 pm
    Okay, that helps… but then how do I change it again after that? It needs to use a total of 4 different tracking points over time.
  • Kevin Camp
    January 14, 2008 at 9:45 pm
    you could use layer markers to indicate the point at which the target should change, the use an expression like this:
    target1 = ;//point at 1st target
    target2 = ;//point at 2nd target
    target3 = ;//point at 3rd target
    target4 = ;//point at 4th target
    if (time < marker.key(1).time) value; if ((time >= marker.key(1).time) && (time < marker.key(2).time)) target1; if ((time >= marker.key(2).time) && (time < marker.key(3).time)) target2; if ((time >= marker.key(3).time) && (time < marker.key(4).time)) target3; if (time >= marker.key(4).time) target4;
    you could probably link the timing to the target layers’ in and out points so you wouldn’t need the layer markers if you needed to be super flexible.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kyle Hamrick
    January 14, 2008 at 9:49 pm
    Based on your descriptions of what you’re doing, you also might consider simply applying your track data from the multiple sources to a single Null, then using that as your actual track point. Depending on the specifics, that may be easier to deal with than some big, messy expression.
    Kyle Hamrick
    Editor/Motion Graphics Artist
    http://www.kylehamrick.com
  • Benjamin Tubb
    January 15, 2008 at 2:26 pm
    Kevin, your idea might do it. That’s interesting, I never knew expressions could interact with layer markers.
    Kyle’s idea is good too, but not all of my ‘tracking points’ are actually ‘tracking points’. Some of them are Point Controls animated by hand frame by frame.
    Thanks for all the help
