Activity Forums VEGAS Pro keyframing changes
  • keyframing changes
    Posted by Gary & yvonne on July 6, 2006 at 10:15 pm
    When I was doing a montage in vegas. After clicking on pan and crop and setting my keyframe at the beggining of the picture, I right click the keyframe and set it to smooth and then I would also set the keyframe Interpslation to SMOOTHE 0.000 with the slider. Then I would do the same at the end of the picture. My problem is some of those settings change on me back to SMOOTHE 1.000 by themselves when i’ve come back to check on them and a couple of them added a extra keyframe in the middle. I would appreciate your help…..thanks, Gary
    Edward Troxel replied 20 years, 2 months ago 2 Members · 1 Reply
  • Edward Troxel
    July 7, 2006 at 2:23 am
    Keyframes in the middle happen when you have the cursor in the middle of the timeline (typically because the “lock” to timeline option is turned on) and you change a setting. As soon as you change the setting, a keyframe is added at that location.
    As for the smoothness setting, you could always use a script to change them all at once.
    Edward Troxel
    JETDV Scripts
