Activity Forums Adobe After Effects Keyframing Camera Pan – what interpolation to use?
  • Keyframing Camera Pan – what interpolation to use?
    Posted by Daniel Hetherington on March 24, 2016 at 1:03 pm
    My workflow got complicated, maybe overly. I made a picture mosaic in photoshop using contact sheet script, then made a card dance out of it.
    I then had to carefully attach a 3d cam using a 3d null (card dance using comp cam). Problem is I want to use the 3d cam to start at a certain card zoomed all the way – no problem – but then every time I change the positioning of a future key frame, it effects the relative positioning of the existing key frames.
    Is this because of key frames not on linear?
    Dustin Parsons replied 10 years, 5 months ago 2 Members · 3 Replies
  • Dustin Parsons
    March 25, 2016 at 11:29 pm
    That shouldn’t happen unless you have all the camera’s keyframes selected before changing the position of the camera. If you don’t have any keyframes selected the new camera position should not interfere with any of the others.
    The interpolation of the keyframes wouldn’t affect this:
  • Spacial interpolation determines with whether the camera moves in a straight light or curved line from one keyframe to another
  • Temporal interpolation determines what speed the camera moves at from one keyframe to another. So it could move at exactly the same speed between keyframes (linear) or it could start fast and slow down or start slow and speed up, or anything in-between
  • Daniel Hetherington
    March 26, 2016 at 4:26 am
    Ah. So when using null dolly for positioning the camera, make sure all key frames are enabled for the cam positioning as well, or all positioning for the null, or both?
  • Dustin Parsons
    March 26, 2016 at 7:51 pm
    I’d suggest using either the Null or the Camera for all moment – don’t keyframe both the Null and the Camera, this will complicate your moves. If you have the Camera parented to the Null and the Null is keyframed throughout the scene and you change the position of the Camera then it will still follow the Null but it’s relative position to the Null will be different. I’m assuming this is what’s happening in your scene.
  • We use anonymous cookies to give you the best experience we can.
